sourcing external .py files
borisb2
Quick question:
I'm running a lot of python snippets (creating specific nodes, ROPS etc.) through a custom menu in houdini. The external python-files are sourced in the MainMenuCommoin.xml via
<label>Submit Caching Job (Non Sequential)</label>
<scriptPath>Y:/_scripts/houdini/submitCachingJob.py</scriptPath>
So far so good.
Now I want to create a button on a node in houdini that also calls one of these external scripts. But here I'm a little stuck as I can't figure out how to actually source an external python-script via the buttons callback-script. In these files there are no functions to import, just plain commands to create/connect/set something in houdini.
What would be an easy way to source an external python file?
Thanks a lot.
Edited by borisb2
Thanks. But even if I'd wrap all commands in a function, how would I source that external py-file in the buttons callback script? .. the file is not sitting in the users directoy but on the server.
Guess I have to look at the execfile function?
You could try something like this in your callback script.
import sys; sys.path.append("/path/to/your/python/module"); import your_module; your_module.main()
As Alexey mentioned make sure your code is wrapped into functions otherwise it will only be run once when the module is imported.
Cheers,
Dennis
hmm ... trying:
import sys; sys.path.append("Y:/_scripts/houdini/setMantraOutput"); import setMantraOutput
but I get "No module named setMantraOutput"..
The file sits here:
Y:/_scripts/houdini/setMantraOutput.py
what am I doing wrong?
hmm ... trying:
The file sits here:
Read the basics of Python modules. You need to append a path to a folder, not to a file, where python can find your module by name.
