Anatol Posted May 26, 2015 Share Posted May 26, 2015 Hi guys! I'm trying to restrict volume density by Bounding Box and Ramp. I created FitRange and Ramp nodes. When I move sphere by Y axis I can modify FitRange MIN and MAX values manually to keep density restricted. But I can't import min and max values and wire them into min and max inputs of FitRange. Is it possible to import attribute into volumevop? cloud_dencity_test_001.hip Quote Link to comment Share on other sites More sharing options...
ranxerox Posted May 27, 2015 Share Posted May 27, 2015 if you want to import an attribute you can use the "import detail attribute", "import point attribute", "import primitive attribute", "import vertex attribute" vops. From what I can tell here, you may want to look at the "bounding box" vop. -G Quote Link to comment Share on other sites More sharing options...
