Add edge between verts
feresteanud
I have started modeling in Houdini and I have a problem (which I can very easily solve in Maya with connect edges, but DO NOT WANT, I want to start learning Houdini) with adding an edge between verts. As you you see in my attached image I only want to add an edge where is the red line is. Which tool should I use?
Thank you
post-13085-0-80228100-1434447759_thumb.j
