Constraining Granular Solids
Hello Everybody,
I figure that this is a very basic question, since I'm a beginner. But I need your help since I'm stuck. :)
I'm playing around with the Granular Solid's inside Houdini and I would like to try to constrain certain grains to different objects. Basically I would like to be able to animate a jiggly granular solid object with a simple rig.
I've tried to use Popvop's after the grainsolver ( before the popsolver ) for this but ofcourse then the popsolver will ignore this.
How would you go about in doing this?
Thanks,
