naruzz Posted June 22, 2015 Share Posted June 22, 2015 Hi Actually, I have a question about a rendering hope that I can get a answer for that. so the question is kind a simple, let's say I have to render bunch of objects and also it include curves which is import from maya. the thing is I need render without curves, so that I only get objects render. so Is there any possible way not render only curves but only objects? since I have lots of nodes, so... I can't type every single node into excluded object in Mantra... Thank you! =) Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted June 23, 2015 Share Posted June 23, 2015 (edited) How curves are imported into Houdini? Polygons? Bezier? 1. Maybe iterate over nodes with Python and delete NurbsCurve/BezierCurve/OpenPolygon types? 2. Or iterate over nodes and add add width attribute and set it to . Edited June 23, 2015 by bad mood 1 Quote Link to comment Share on other sites More sharing options...
naruzz Posted June 23, 2015 Author Share Posted June 23, 2015 Thank you for the answer. I'll try as soon as when I get back to office which set the width to . Quote Link to comment Share on other sites More sharing options...
