Start keyframe animation on every particle event in maya
hello friend
I should ask this in maya forum but i am little unaware of maya background, anyway
i am little new in maya, probably this solution can be easily possible in houdini. i have an scaling keyframe animation in sphere and it is instance with particles. Now i need to trigger sphere animation on particle event, mean every time when particle collide with plain the event will occur sphere animation
I tried with event editor but every time animation is playing same in every instances , is there is any way to start sphere animation with every event from the begining.
I WILL GREAT FULL , IF ANYONE COULD HELP
Edited by Elena_ DeCosta
  • 2 months later...
Maya's particle instancer is a bit ancient, but you can do this.
The limitation here is that you can't use keyframed animation; the instancer can, like its name implies, only instance a node or nodes, so the keyframe animation would be identical on all instances.
What you'll need to do is:
  • figure out how many frames of animation you need (let's say you have 10 frames of animation)
  • for every frame, duplicate the sphere
  • add all these spheres to your instancer node, note how they are ordered, this is important
  • add an 'indexPP' per-particle float attribute to your particle
  • on the particleShape, under the instancer options, set 'index' to 'indexPP'
Now you can control which instance is shown via the indexPP attribute.
Your task now is to animate this indexPP attribute when the particle hits something. Create a per-particle runtime expression on your particles like this:
if( event && indexPP < 10 ) {
    indexPP++;
Adding an 'event' attribute allows the particle to know when it's collided with something. As long as it's 0, the particle hasn't collided with anything.
See attached file.
instance_sphere_anim.maFetching info...
  • 2 months later...
  • 1 year later...
