skogen Posted July 16, 2015 Share Posted July 16, 2015 Hi! I have pyro sims on the disk, including vel fields, using .vdb file format. I use a point instance procedural to load the caches. The points are not moving, no point velocity. I need rendered 3d motion blur on the fluids coming from each instance`s velocity field. Is it possible? Thank you in advance! Cheers Quote Link to comment Share on other sites More sharing options...
skogen Posted July 16, 2015 Author Share Posted July 16, 2015 Solved... Quote Link to comment Share on other sites More sharing options...
