Deforming fracture object
Navneet Arora
Hello guys,
   I am trying to do RnD on deforming fracture, so i took a sphere , animated it and then after fracturing i assigned it the deforming position . for activation i selected some points over the time and in sop solver i took point wrangle and assigned that if active>0 then deforming would be 0 in order to stop the frags from deforming but now the problem is that it is not inheriting the velocity of the original object which is fractured.
Please have a look at the attached file and if somebody could help.
deforming_object.hip
Edited by Navneet Arora
