Nick da Silva Posted July 31, 2015 Share Posted July 31, 2015 Hi all I'm trying to constrain active objects in DOPs to deforming geo. The problem is that since the constraint network is only being created on frame 1 then inside of DOPs the constraints don't update with the deforming geometry. I can't import the constraint network every frame either because then the constraints are recreated every frame even if they were deleted the previous frame. Does anyone have a good workflow for this or suggestions? Thanks! Quote Link to comment Share on other sites More sharing options...
Nick da Silva Posted August 4, 2015 Author Share Posted August 4, 2015 (edited) I've attached a very simple scene demonstrating the problem. I really hope someone can help with this. Thanks. constraints4.hip Edited August 4, 2015 by Nick da Silva Quote Link to comment Share on other sites More sharing options...
