How to read array
If I have a point attribute of type array, how can I get that array and store the values in a UT_FloatArray?
I tried the following but somehow it does not work.
GA_ROHandleFA distH(gdp, GA_ATTRIB_POINT, "dist");
UT_FloatArray distances;
for(GA_Iterator it(gdp->getPointRange()); !it.atEnd(); it.advance())
    GA_Offset offset = it.getOffset();
    distances = distH(offset);
Thanks in advance!
Edited by resonanz
Well its usually best to say why something doesn't work, so someone can have a starting point to figure out the problem.
From what I see though, you're assigning a float value to UT_FloatArray.  A float is not a UT_FloatArray.  Your attempting to make UT_FloatArray == float, when what you want to is store the float inside the array object.
distances.append(distH(offset));  should solve that problem.
You are right! Sorry about that!
The problem is that GA_ROHandleFA is a handle for an array not a float like in your example. I did check if the handle is valid and it is but as soon as I try to get the array from the attribute with distH(offset) I get the following error message:
"error C2064: term does not evaluate to a function taking 1 arguments".
The thing is that I have no idea what other argument(s) I should use instead.
