wobbling particles around animated curve
houdini1987
Hello everyone,
I want to create an effect (as shown in picture) where particles are emitted from an animated curve (like sine wave) like for 2 sec and the those particle keep wobbling around that curve. Its like curve is surrounded with those particles but in random fashion like outer radius of a hollow pipe.
Any lead in this will be helpful.
Thanks in advance.
post-10148-0-96054900-1440574378_thumb.p
If you make a pop network there is a popcurveforce node that can do exactly that.  Use your curve to emit particles and then use that same curve in the popcurveforce with the orbit value turned up.  It is a relatively straight forward node, so if you play with the values you should be able to figure it out.
Thank you Richard, Let me try and get back here.
