treebucks Posted August 27, 2015 Share Posted August 27, 2015 when i select multiple primitives, points or edges and press the transform tool, a lot of times the transform tool handle is not pointing at a straight line, it's pointing diagonally. is there a way that you can make that transform handle point to the XY or Z position? Quote Link to comment Share on other sites More sharing options...
nord3d Posted August 27, 2015 Share Posted August 27, 2015 This behavior can be set at: Houdini Preferences -> Handles -> Default Handle Alignment Quote Link to comment Share on other sites More sharing options...
treebucks Posted August 27, 2015 Author Share Posted August 27, 2015 thanks Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 28, 2015 Share Posted August 28, 2015 The 'm' key cycles through the handle alignments, 'shift' & 'm' reverse cycles Quote Link to comment Share on other sites More sharing options...
