the select loop command
i'm going through some of the tutorials from the houdini website. many of the tutorials are for older versions of houdini. there is a select loop command in those tutorials, the SHIFT L. when i select an edge and press SHIFT L with the version 14, nothing happens. is there still a select loop command in version 14?
