particleMan Posted November 18, 2004 Share Posted November 18, 2004 I'm looking for a utility that can take an AVI file (or any movie file format for that matter) and convert it into a series of individual frames. Preferably the utility is FREE and preferably on Linux, but a free Window$ utility is acceptable. Anyone know? Thanks! Alex Quote Link to comment Share on other sites More sharing options...
crunch Posted November 18, 2004 Share Posted November 18, 2004 I'm looking for a utility that can take an AVI file (or any movie file format for that matter) and convert it into a series of individual frames. Preferably the utility is FREE and preferably on Linux, but a free Window$ utility is acceptable. Anyone know? Thanks!Alex 15056[/snapback] I direct you to http://odforce.net/wiki/index.php/CreatingMovieFile the wiki. Quote Link to comment Share on other sites More sharing options...
particleMan Posted November 18, 2004 Author Share Posted November 18, 2004 I direct you tohttp://odforce.net/wiki/index.php/CreatingMovieFile the wiki. 15058[/snapback] This explains how to create a movie file from an image sequence. I want to go the other way, create an image sequence from an avi file. Alex Quote Link to comment Share on other sites More sharing options...
crunch Posted November 18, 2004 Share Posted November 18, 2004 This explains how to create a movie file from an image sequence. I want to go the other way, create an image sequence from an avi file.Alex 15063[/snapback] Sorry about that... When I run % mplayer -vo help It lists video output drivers of pbg and jpeg as well as gif89a (which says that it will create an animated GIF file). It appears that it's as simple as running % mplayer -vo jpeg foo.avi Quote Link to comment Share on other sites More sharing options...
particleMan Posted November 19, 2004 Author Share Posted November 19, 2004 Sorry about that... When I run% mplayer -vo help It lists video output drivers of pbg and jpeg as well as gif89a (which says that it will create an animated GIF file). It appears that it's as simple as running % mplayer -vo jpeg foo.avi 15064[/snapback] Thank you VERY much! I knew there had to be a way with mplayer, but I couldn't figure out the syntax! Alex Quote Link to comment Share on other sites More sharing options...
