accessing object centroid in vop
ltmedic
Hey guys
I guess the title says it all but i'm unclear as to how to access an objects centroid within a VOP network. I'm wanting to use the centroid of the object to help create a custom velocity field to push velocity away from the centre of the object.
Thanks
You can use the bbox vop and then average the min and max with average vop, this will give you the centroid.
However this calculation would be performed for every point/voxel/prim whatever the vop is set to run over.  An alternative is to just make a vector parameter with the usual: centroid(opinputpath('.',0), 0) centroid(opinputpath('.',0), 1) centroid(opinputpath('.',0), 2)
Either one should be fine.
  • Like 2
