Particle Stacking Effect Help
talen.herzig
Hi all.
I'm trying to create a particle stacking effect, where the particles collide with a surface and stack on top of each other. However, I'm not entirely sure how to go about this. I'm using volumes, as I saw in a different video, but cannot quite get the expected results. Upon collision with the ground plane, the particles are stopping and creating the collision volume, but it's not growing on itself. Any help would be much appreciated. I'm quite new to the volume aspect of DOPs, so I'm not entirely sure how to get it all to work, nor why the particles aren't growing the DOP. I've tried tweaking quite a few settings and playing with this over the last hour or two, but once again am not sure what I'm missing.
Please find the .hipnc file attached below. Cheers.
tasty soup v5.hipnc
Great :).
i was about to send you the same video. Good you found it :)
Yes Rohan has created a great video. Explained Grains in simple terms. Thanks to  Rohan as well :)
Also let me know if you face any problem in Grains because i keep testing it and might help you in that as well.
Cheers !!!
