Ocean surfaces --> Wave tank
Aram86
Little question about communication ocean waves with wave tank.
I Created ocean waves surface used 5 times ocean spectrum to get ocean as i want ( compare created surface to other one from different simulation , so was little complicated).
Now when i got that , i try to create wave tank who will get that ocean surfaces as surface. But i got problem with import that. Normal use object merge (ocean spectrum) and all work right. Now i got 5 ocean spectrum one by one , and each do something with surface. How can i import that that to wave tank in smart way ?
In end i need get particle foam from that (and that is goal ). I attach file with my project.
Or it's impossible to do it (in not so  much complicated way) , and i need to chose one ocean spectrum to generate my wave tank ?
ForumFile.hip
Edited by Aram86
