Yorkst Posted October 12, 2015 Share Posted October 12, 2015 Here is a stream of particles with initial downward velocity and no gravity. The lowest object is a cube and the one in the middle is a box, though they both look like cubes in this projection: Here I set offset surface parameter of cube's static object to 1: It displaced the position, where particles appear after collision, by one. But didn't displace the position where particles start colliding by the same value. I can achieve equal displacement by setting Volume Offset of popobject to 1. But it will affect collisions wtih all objects, not just the cube: I also can use a bigger invisible cube in this particular case, but it won't do with more complex geometry. Can I achieve the result like in third picture, but only for a cube? Quote Link to comment Share on other sites More sharing options...
