Yorkst Posted October 16, 2015 Share Posted October 16, 2015 I'm new to Houdini and follow a basic tutorial for Houdini 9, though my version is 14.0.444 In it, a source of particles was created. Y component of velocity of each particle was set to zero. Then modelled mice were added to particles with POP instance. To prevent mice from colliding each other, the author used POP Interact with a force of 100. It made some mice fly in the air after collision. In Houdini 9, it was possible to set vector of force in POP interact to (100,0,100), which solved the issue. In Houdini 14, I can only set the magnitude of this vector. So, mice particles either penetrate each other, or fly in the air. POP speed limit also works with magnitude only. Does axis speed limit exist in newer versions of Houdini? Quote Link to comment Share on other sites More sharing options...
Netvudu Posted October 16, 2015 Share Posted October 16, 2015 Well, POP Interact just changes the particles force attribute, so it should be perfectly possible with a little bit of VEX/VOPs to change that per axis. Quote Link to comment Share on other sites More sharing options...
Yorkst Posted October 16, 2015 Author Share Posted October 16, 2015 (edited) Thanks! Is it possible to use Python instead of VEX for this purpose? I know, how to create Python SOPs. But File->New Operator Type/Python Type doesn't list "Particle Operator" in "Network Type" list. Edited October 16, 2015 by Yorkst Quote Link to comment Share on other sites More sharing options...
Yorkst Posted October 16, 2015 Author Share Posted October 16, 2015 (edited) I solved it with adding a POP VOP node and editing its contents like this: If I want to code instead of editing nodes, can I do it with Python? How can I start doing it? Edited October 16, 2015 by Yorkst Quote Link to comment Share on other sites More sharing options...
