change mapped constraint strength dynamically - Effects - od|forum Jump to content
WLVL
I have a building with glue constraint strength mapped along the y axis (+ painted in some spots).
I'd like to change the constraint strength over time to choreograph the structure destruction/collapse.
I am keyframing the points of my constraint strength ramp in SOP. How do I pass that info in DOP?
In the constraint network DOP there's the option Overwrite with SOP if time dependent.
I don't want an overwrite since this option will restore also broken constraints freezing flying pieces in air.
I'd like to update the strength of "survived" cons.
I'm thinking about a att wrangle in a SOP solver, but im not sure how to set it up.
thanks very much for helping!!
simplified hip file attached
dynamic_glue_strength_question_198.hipFetching info...
