aoisaki Posted November 4, 2015 Share Posted November 4, 2015 (edited) I watch houdini workshop about vex wrangle Then i buy the book Generative Design I like the noisy movie very much! But when i want to work that in houdini There are too many stuff is different Something I can find like TWO_PI but something I can't like noise function noise ( noiseX,noiseY) void setup void draw PVector Did there some website have java to vex translate thank you! Edited November 4, 2015 by aoisaki Quote Link to comment Share on other sites More sharing options...
f1480187 Posted November 5, 2015 Share Posted November 5, 2015 You need to understand both languages on some intermediate level. Essential part is to understand which code pieces are interchangeable and which are not. Implementation and architecture-related things usually cannot be translated, except cases where frameworks are very similar. On the other side, the algorithms itself usually can be translated from math formulas, pseudo-code from Wikipedia or pieces of code written in other programming languages. Syntax may be very similar and types, constants, functions are usually same too. Trigonometry, linalg, ray-trace, noises and PRNGs may be implemented differently but do the same job. For example, it will take you about an hour to translate 2D intersection algorithm written in C to VEX version. The bonus is the VEX code tends to be more accurate, taking less lines. Authors of libraries usually provides some utility functions and classes taking thousands of lines of hard C++ code, but we always have big and friendly framework called Houdini. Sometimes it is better to go outside VEX and place couple of SOP nodes computing some useful attributes. void setup and void draw routines seems to be part of Java/Processing framework doing internal stuff unrelated to visual algorithms, there is no VEX alternative. PVector looks like normal VEX's vector type, probably treated as position (you want to transform positions when doing some deforming, but you do not want to transform colors, in all other cases both position and color vectors can be treated as same 3-float structs). You need to understand what exactly that noise function returns and gets as an arguments. noise(noiseX, noiseY) looks like a Perlin/Simplex noise getting a position as an argument, like all normal noises does. It returns a float and gets a 2D vector as an argument (actually, 2 floats, not 2D vector, but it is implementation details). There is no float noise(vector2) function signature in VEX at this moment, but float noise(vector) is available. vector pos = @P; // Obtain position. pos = set(pos.x, pos.y, 0); // Set Z value to zero, simulating 2D input. float result = noise(pos); // Call "float noise(vector)" function. @Cd = result; // Set point colors to that noise value to see the result. The last line is poor man's "draw" functionality. Place an XY-grid, connect a Point Wrangle and paste the above code in it. You will see the noise. See attached scene. noise.hipncFetching info... 1 Quote Link to comment Share on other sites More sharing options...
aoisaki Posted November 6, 2015 Author Share Posted November 6, 2015 On 11/5/2015 at 2:36 PM, f1480187 said: You need to understand both languages on some intermediate level. Essential part is to understand which code pieces are interchangeable and which are not. Implementation and architecture-related things usually cannot be translated, except cases where frameworks are very similar. On the other side, the algorithms itself usually can be translated from math formulas, pseudo-code from Wikipedia or pieces of code written in other programming languages. Syntax may be very similar and types, constants, functions are usually same too. Trigonometry, linalg, ray-trace, noises and PRNGs may be implemented differently but do the same job. For example, it will take you about an hour to translate 2D intersection algorithm written in C to VEX version. The bonus is the VEX code tends to be more accurate, taking less lines. Authors of libraries usually provides some utility functions and classes taking thousands of lines of hard C++ code, but we always have big and friendly framework called Houdini. Sometimes it is better to go outside VEX and place couple of SOP nodes computing some useful attributes. void setup and void draw routines seems to be part of Java/Processing framework doing internal stuff unrelated to visual algorithms, there is no VEX alternative. PVector looks like normal VEX's vector type, probably treated as position (you want to transform positions when doing some deforming, but you do not want to transform colors, in all other cases both position and color vectors can be treated as same 3-float structs). You need to understand what exactly that noise function returns and gets as an arguments. noise(noiseX, noiseY) looks like a Perlin/Simplex noise getting a position as an argument, like all normal noises does. It returns a float and gets a 2D vector as an argument (actually, 2 floats, not 2D vector, but it is implementation details). There is no float noise(vector2) function signature in VEX at this moment, but float noise(vector) is available. vector pos = @P; // Obtain position. pos = set(pos.x, pos.y, 0); // Set Z value to zero, simulating 2D input. float result = noise(pos); // Call "float noise(vector)" function. @Cd = result; // Set point colors to that noise value to see the result. The last line is poor man's "draw" functionality. Place an XY-grid, connect a Point Wrangle and paste the above code in it. You will see the noise. See attached scene. Thank you very much ! Quote Link to comment Share on other sites More sharing options...
