Druidl Posted November 19, 2015 Share Posted November 19, 2015 Hi,I'm trying to swap the low res geo from a dop.The ussual workflow transform pieces does not work with newly emmited objects.So can someone share some insight?I could do it without emmiting new objects and just have them somewhere in the scene before they are needed, but I would like to find out how is something like this solved? Quote Link to comment Share on other sites More sharing options...
jujoje Posted November 19, 2015 Share Posted November 19, 2015 If you're using packed geometry you could possibly use the Packed Disk Edit node to change the disk path to point to the highres object: http://www.sidefx.com/docs/houdini15.0/nodes/sop/packeddiskedit Quote Link to comment Share on other sites More sharing options...
