Saya Posted November 21, 2015 Share Posted November 21, 2015 (edited) Hello ODforce, I have an issue about the point node. I want to direct the point normals outside diagonally from a square. On these 4 points I would want to copy a model using the copy sop, to get a result as shown on the image. Doing it that way I think I can adjust the size of my square. Sadly enough I don't know how I can direct the normals using the point node. I got this result by having the model copied 4 times and increasing its rotation 90 degrees per copy. That's not the method I want to use. Can someone please help me out edit: I thought a quick file would help Table Legs.hipnc Edited November 21, 2015 by Marcomeeuwse Quote Link to comment Share on other sites More sharing options...
Maurits Posted November 21, 2015 Share Posted November 21, 2015 Did you try using the Polyframe node. This node can generate the N vector but also the tangent and bitangent.In your case use the Tangent value as N and put the style to First edge.You might have to rotate your object 180 degrees but it should work. Table Legs example.hipnc Quote Link to comment Share on other sites More sharing options...
Saya Posted November 21, 2015 Author Share Posted November 21, 2015 Many thanks Quote Link to comment Share on other sites More sharing options...
