rakson Posted December 17, 2015 Share Posted December 17, 2015 (edited) Hi, Ive got problem with lava flip simulation. In shelf setup of viscouos fluid i made some changes but thats not the point. Point is that ive got some problem with caching/simulating. Everything is ok (frame simtime is around 6-8 minutes res 0.025) and after around 50 frames everything slow down to 25-30. After few slow frames everything stop (cpu usage is 0% ram is full and nothing happens for about an hour or maybe more). System spec is 2xXeon 6c/12t, 48GB of Ram, Windows 7. Im using Non-commercial version of Houdini 15 (build 15.0.313). Im attaching my hipnc (unfortunattely cant attach geometry because im not permited). NEW TERRAIN NEW SIMv7_changes_v2.hipnc Edited December 17, 2015 by rakson Quote Link to comment Share on other sites More sharing options...
Guest tar Posted December 17, 2015 Share Posted December 17, 2015 Windows is quite terrible with memory management. Try using a linux install. Quote Link to comment Share on other sites More sharing options...
