Convert SDF to fog produces blocky volume
legomir
1) use polygon sphere with high resolution so that is smooth. using a primitive causes an auto conversion that's why you get an error on the vdbfrompolygons node
2) most important :use smaller voxel size
3) use fog vdb in the vdbfrompolygons node so that you can avoid the conversion
problem 1.hip
