implicit ptnum for second input in VOP
WLVL
Hello!
in VOP the ptnum is called with a parameter node for the first input (geometryvopglobal)
i used an importpoint attribute with sign: integer, input: second input, attribute: ptnum
but it returns me zero.
if i want the ptnum for the other inputs do i have to create the point number attribute ahead?
is the ptnum like an implicit attribute?
thanks for helping!!
I think ptnum only gets the ptnum of the current point being processed.
Depends on what you wan't to do. if you want to get an attribute from the second input with the same number you can use the @ptnum as target point in the "point" function.
But if you want to iterate over all the points in the second input for each point in the first you can also use a for loop with the total number of points of the second input as goal.
So knowing what your goal might help for a better answer.
