Loading point position from .chan file question
notintricate
I have a .chan file with tx ty tz channels
I assume that each new line in file should be new point position at frame.
So I created chop network with file chop inside.
In OBJ context I have created Add node and plugged it into channel node, it creates a point, but position doesn't change with new frames.
I tried to add record chop after file chop (record input and record output set to "current time slice") and it almost does what I want but for some reason it duplicates some frames...
So what is the proper way to load these point positions to change at each new frame?
