Glue constraint references unkown object
Gorrod
I'm trying to fracture some geometry, run over the fractured pieces and fracture them again in a for each subnetwork and create constraint geometry along with it in the loop.
In the end I want the fractured pieces created in the loop to have a stronger glue bond than the rest.
Right now I am stuck because the constraint network doesnt recognize the constraint geometry. ("Glue constraint references unkown object")
It's probably the simplest of problems, but I just can't figure it out, help much appreciated.
constraints_for_each_subnet.hipnc
It seems to be because of a discrepency of the name attribute between the actual pieces and the constraint primitives. If you go inside your for loop you are editing the name attribute for the pieces but the constraints are created before you do this. If put the connectadjacentpieces node after the 'attribwrangle1' node it should work.
