Particle caching options for a FF render (0.4 inc)
Hi
I'm trying to cache to disk a POP particle simulation that has a value of 3 for the 'sub steps'  parameter. I want to be able to render/work on it later using the FF (0.4 inc value) as well and bring back the cached bgeo.sc on the correct frame range for some other post sim adjustments.
So far I was only able to cache the sim files to disk and render/work with that by loading the sim files with the POP Network node itself (in order to avoid cooking again).
Is there any better workflows?
Thank you!
cheers
Cristian
ParticleCaching_v02.hiplc
Why not using already provided tab CACHE on your POP node? Just simply turn on option SaveCheckPoints (with default options it will cache every subframe ) and use $SF (simulation frame local variable) not $FF. In your case it will save 30 frames (150 - 180). Your range is 50-60 so it internalu calculate new range as:
start: $FSTART * substeps
end: $FEND * substeps
later in your reading node just do math depend on you want: /cache.$F*substeps.sc will read every third frame from saved range if you play it from your current range 50-60. Or you can drop frame increment to 0.3333 with that it will read all 30 frames but you have to change expression for index to    trunc($FF*substeps)
