Adam Ferestad Posted March 31, 2016 Share Posted March 31, 2016 [Cross post with SideFX forum] I have been looking on some math forums and posting for a couple of days and it occurred to me that the Houdini forums should have some people who know about this stuff too. I am currently working on my MA project at SCAD and I have elected to create a tool that will allow an artist to make a history dependent distribution of an attribute over a mesh. The process I have in mind for the tool working will go like this: Artist gives the mesh with an initial state of attributes on it, be it from prim/point attributes of from a map they have painted. I make sure all of the normals are calculated. Scatter points densely on the mesh and transfer normals and the attribute we are diffusing. Iterate over the points and measure a small neighborhood around each point to capture the point numbers for calculating over. Perform a quadratic approximation of the attribute over the neighborhood <---- This is where I am right now Calculate permeability attributes (not wanting to give away too much on this just yet) Loop: 1. Gather permeability data, 2. Calculate the permeability of each point based on float ramps which represent timelines, 3. Advect attribute Save the data to a map, which can then be used by the artist to control downstream aspects of the scene. I am currently having some trouble with the basic diffusion step. I am trying to get a system working which will be able to advect the attribute over the point cloud before I worry about the permeability stuff. I have a good idea what I am going to do for all of that, but this part is throwing me for a loop. I am working with this general equation: Considering that the little o should be virtually 0, at this point I am considering it negligable, ΔS will be the search radius for the neighborhood generation, Δt will be 1 for all intents at this point, since it is basically just an arbitrary step in the loop. Inside the inner product, v is defined in the documentation as a normal, so I am pretty sure that should be the surface normal, which I will capture from the original geometry. The other term in the inner product is the "Flux Vector" which is what I am currently trying to figure out how to calculate. The current formula I have is: Utilizing the first equation, D should be a diffusion constant which controls the speed of diffusion (as I understand it), though someone on a math forum mentioned that it could be a tensor matrix, something to look into later when I get the basic working. The real issue for me is coming from the grad(n). Since I am looking at a point cloud, which is essentially 4 dimensional at the minimum, meaning A = n(x,y,z), I am trying to figure out how to manage the partial differential calculations around the point. That is where the concept of using the neighborhood to find a quadratic approximation came from. I know that one could easily calculate the partial differentials of the approximation, but getting that approximation is proving... interesting. I am relatively sure that the advection step should be fairly straight forward as A_(t+1) = A_t + ΔN*P(x,y,z). I am not sure if I should be working in 4 dimensions, of if I should be transforming the neighborhood to the origin and projecting the points into a plane, then using the attribute as the output for a 2d mapping. Or is there an easier way to look at/solve the whole problem? I am not sure if this it the right forum to be asking this in either, but I figured that scripting was going to have the most people who might be familiar with the more theoretical aspects of how these things are produced. I am including the file I have been working in, so you can see the direction that I have been taking as well as what I have been attempting. initialDevelopment_Stickies.hipnc Quote Link to comment Share on other sites More sharing options...
