friedasparagus Posted April 9, 2016 Share Posted April 9, 2016 (edited) Hello all, Can anybody shed some light on the 'deafult state' field in the type properties window? It is mysteriously absent from the documentation on the type properties window. I've only used it so far to expose a stroke SOP to the HDA as per this post... I haven't had any luck with any other values and I'm curious as to what exactly the 'default state' parameter is addressing. Thanks in advance EDIT: As usual, the moment you ask, you find out. So the docs for the stroke SOP say that the node is 'paired with a stroke state', so it's sounding like this is something fairly unique to the stroke SOP, is this the case? Or are there any other states going? Edited April 9, 2016 by friedasparagus Quote Link to comment Share on other sites More sharing options...
