melc92 Posted April 14, 2016 Share Posted April 14, 2016 Hi! I have a shot that I'm working on, where I have tracked footage and brought it into Houdini. The issue I'm having is that I want to render the shapes without the stairs from Houdini, however if I turn the stair layer off then the stairs won't cut into the shapes like it needs to as the shape is sitting on the step? I know in Maya, you would use a surface_shader for this but I have no idea what the equivalent to that would be in Houdini. I have attached image to show what I mean as I'm not the best at explaining things. Any help at all would be great! Thanks, Mel. Quote Link to comment Share on other sites More sharing options...
davpe Posted April 14, 2016 Share Posted April 14, 2016 set the stairs object as an Forced Matte in Mantra ROP (Mantra ROP > Objects > Forced Matte) Quote Link to comment Share on other sites More sharing options...
zoki Posted April 14, 2016 Share Posted April 14, 2016 you can also use shadow matte shader on stairs so you get objects shadows on the "invisible stairs" then render objects separate with stairs as phantom>under render tab on geometry node then you should have all to do the comp Quote Link to comment Share on other sites More sharing options...
melc92 Posted April 15, 2016 Author Share Posted April 15, 2016 Thanks! Quote Link to comment Share on other sites More sharing options...
