dpap Posted April 17, 2016 Share Posted April 17, 2016 I am trying to modify the "paintfogvolume" digital asset so that it has an erasing function as well. ( Setting density to -1 at first seemed to work as erase but you can't paint/add fog again, in areas that you erased) So I thought of using "grouppaint" to define with a brush which edges to delete from the curve that the "drawcurve" creates. The concept works but building a new interface for the modified digital asset is tricky. How can I expose the handle of the Grouppaint node . Right clicking on the handle itself doesn't give me the usual option " export handle to digital asset". And how will be able to choose which handle of the to use? There is already a handle from the Stroke node , if I export the one from the Grouppaint as well how will I be able to choose between the two, so that with the first handle I paint and with the other I erase? paint_or_erase_fog.hda paint_or_erase_fog.hip Quote Link to comment Share on other sites More sharing options...
