manx151089 Posted May 2, 2016 Share Posted May 2, 2016 (edited) Hi, I am trying to paint on specific areas of my shards and scatter points on them using for each loop and then further fracture them.But the problem is I painted the areas with red and scatter is not able to use the attribute Cd to scatter in only the painted areas. Also, I wanted to randomize the seed of the scatter inside the for each loop per shard. Hope you guys could help me with the same. Thanks, Manishkumar M. Edited May 2, 2016 by manx151089 Quote Link to comment Share on other sites More sharing options...
woodenduck Posted May 4, 2016 Share Posted May 4, 2016 You should be able to scatter based on Cd if you check the density attribute box and change the attribute to Cd. You can randomise the scatter inside the for each with a stamp expression. See attached. randCdScatter.hip 1 Quote Link to comment Share on other sites More sharing options...
manx151089 Posted May 6, 2016 Author Share Posted May 6, 2016 Thank you so much Joe! Cheers! Quote Link to comment Share on other sites More sharing options...
