attribute not defined correctly
Blacklisted_Guy
I started working on some vex practice and decided to use it for a switch and a bunch of statements
I've wrote this script  but the second if statement (rot =1 && flip = 0) doesn't seem to be giving the right value.
int rotatetion= ch("rot");
int flipvalue= ch("flip");
@switch = 0;
if ( (rotatetion == 0) && (flipvalue == 0)) {
    @switch = 1;
if ( (rotatetion == 1) && (flipvalue == 0)) {
    @switch = 1;
if ( (rotatetion == 0) && (flipvalue == 1)) {
    @switch = 0;
if ( (rotatetion == 1) && (flipvalue = 1)) {
    @switch = 0;
rot and flip are integer sliders on the attribute wrangle node itself.
for integer, use chi() rather than ch()
Similarly, you should probably defined your switch attribute as an integer: i@switch
Edit: should have tested it before, it does not fix your problem. However adding some else statements works:
int rotatetion= chi("rot");
int flipvalue= chi("flip");
i@switch = 0;
if ( (rotatetion == 0) && (flipvalue == 0) ) {
    @switch = 1;
else {
    if ( (rotatetion == 1) && (flipvalue == 0) ) {
        @switch = 1;
    else {
        if ( (rotatetion == 0) && (flipvalue == 1) ) {
            @switch = 0;
        if ( (rotatetion == 1) && (flipvalue = 1) ) {
            @switch = 0;
Edited by iamyog
i@switch = 0;
    @switch = 1;
else {
        @switch = 1;
    else {
            @switch = 0;
            @switch = 0;
that worked! Thank you so much
