Blending ocean waves with a flip tank
bread25
Hello Everyone,
First time poster and I'm somewhat new to Houdini. I'm currently working on a stormy sea environment where I'm following a tutorial that unfortunately was created with Houdini 13. I have managed to follow the tutorial so far and with a bit of googling have found what replaced what in Houdini 15. But I'm stuck on this part, in the tutorial the teacher uses a VOP SOP which I have made visible via the text port. Inside the VOPSOP he uses a Ramp Parameter which is connected to a addattrib node which has an input that says 'adata', since that input got removed in 14, is there a way around this? The node in question can be found at obj > splashtank_fluid > fxFlipOceanBlend > vopsop_blend.
Houdini 13 add attribute node layout
Sorry that it's somewhat blurry.
Houdini 15 add attribute node
I have added the Houdini file below.
Stormy Sea 19.5.16 v1.hiplc
Edited by bread25
