dfmn Posted May 31, 2016 Share Posted May 31, 2016 Hey guys n gals Im trying to figure out how to convert my outline edges of a voronoi fracture to nurbs. I got the edges selected but I dont know how to go from there. Any suggestions? Thanks! Check out my file select_outside_edges.hiplc Quote Link to comment Share on other sites More sharing options...
f1480187 Posted June 1, 2016 Share Posted June 1, 2016 (edited) By using Houdini 15.5 new Dissolve. Two ways, actually. edges_to_curves.hipnc Also, on Houdini <15.5 or instead of Dissolve you could use Divide with Remove Shared Edges turned on, since your edges are geometry border edges. Edited June 1, 2016 by f1480187 1 Quote Link to comment Share on other sites More sharing options...
dfmn Posted June 1, 2016 Author Share Posted June 1, 2016 5 hours ago, f1480187 said: By using Houdini 15.5 new Dissolve. Two ways, actually. edges_to_curves.hipnc Also, on Houdini <15.5 or instead of Dissolve you could use Divide with Remove Shared Edges turned on, since your edges are geometry border edges. wow thats awesome! Thanks! Quote Link to comment Share on other sites More sharing options...
