pax Posted July 20, 2016 Share Posted July 20, 2016 Hey all, I have a problem with motion vectors from houdini that I want to use in nuke. I really don't know if it's a houdini or a nuke problem. But maybe someone can help me with this. When I apply the vectorblur to my image in nuke, everything (amount/direction/…) works as it should. The only problem are the artifacts you can see in the attached image. Here's how I set it up: In houdini I used the getblurP nodes which are multiplied by my resolution. In nuke I shuffled the vector plane into the motion plane and that into the vectorblur node. I checked all the posts I found but none of them explained anything about this artifacts. If any of you have had the same issue and found a way to fix it, it would be immensely appreciated if you could give me a hint to point me in the right direction. Thanks in advance! motionVectorProblemNuke9.nknc motionVectorProblem.hip Quote Link to comment Share on other sites More sharing options...
Guest tar Posted July 20, 2016 Share Posted July 20, 2016 Nuke10 has a better VectorBlur. Quote Link to comment Share on other sites More sharing options...
pax Posted July 21, 2016 Author Share Posted July 21, 2016 Thanks for the reply! We currently use Nuke 9 in production.... But we probably switch to Nuke 10 some day. So I tried it. The result is much better. The only problem are those little lines you can see in the attached image. Do you know how to get rid of them? Quote Link to comment Share on other sites More sharing options...
