vinshm Posted August 18, 2016 Share Posted August 18, 2016 pre random rotation then orient.. hi!Some questions,just can`t get this effect in instance!could anyone help~!thx! rotate_in_copy_H15.hip Quote Link to comment Share on other sites More sharing options...
MirrorSword Posted August 19, 2016 Share Posted August 19, 2016 Could you explain in more detail what you are trying to achieve? Do you want the particles to first have a random rotation applied, and then be rotated based on the particles velocity? Quote Link to comment Share on other sites More sharing options...
vinshm Posted August 22, 2016 Author Share Posted August 22, 2016 On Saturday, August 20, 2016 at 4:30 AM, MirrorSword said: Could you explain in more detail what you are trying to achieve? Do you want the particles to first have a random rotation applied, and then be rotated based on the particles velocity? yes,that`s what i want.sorry about my english,just can`t get an idea to deal with this keep random rotation state first in instance Quote Link to comment Share on other sites More sharing options...
MirrorSword Posted August 23, 2016 Share Posted August 23, 2016 So I made an example of how I would accomplish that task. If you check out this page. You'll see that the "rot" attribute is a final rotation applied after all the other rotations. So if your points have "v" and "rot" attributes, the objects will first be rotated in the direction of the velocity and then rotated by the "rot" quaternion. I also calculate the "rot" attribute before the particle system so that it won't change during the simulation (although it shouldn't matter for this example). to calculate the rot attribute I use the point number to create a random vector within the range 0 to 1 and then remap it to the range -1 to 1. I then normalize that and use "look at" to convert it to a matrix that points in that direction, and then finally convert that matrix to a quaternion. There's probably a better way to calculate that but this works. Anyway let me know if you have any questions. rotate_in_copy_v2.hip Quote Link to comment Share on other sites More sharing options...
