Bullet Basic Questions
henrik.g
Hey everyone,
I am trying to wrap my head around Bullet some more and wanted to clear some questions, so i'm solid there...
1.Units I:
I found this info on the web:  "A 12 pd started with a muzzle velocity of about 1769 Feet Per Second "
If I was to set this up: Then Mass would be 6 and Initial Velocity would be 539, correct?
2. Units 2:
If I would want to compute Mass - and lets assume Iron - then I can just check in with Wolfram Alpha and use their 7874kg/m3, correct?
3. Units 3:
Glue Strength, is there any "real world" counterpart? Or a formula that describes whats going on, or is this just artistic choice?
4. Settings:
Bullet Constraint Iterations: This seems to have an massive impact on the outcome, is this normal?
5. Workflow:
Is Object-Merging within the same SOP acceptable? I think with all these connections from left to right is kinda cluttered...?
This all leads to my HIP.
I have 2 thin sheets of "concrete" or whatever and want a sphere to pass through, yet what ever I do, however low I set Glue Values and so on, everything will collapse, but the Sphere wont pass through?
Is there anything I got wrong??
Thanks for any help!
Best regards!
cantPassWall_v02.hiplc
