Transforming Velocity or Direction vector
jkunz07
Hey,
I think you can just turn the velocity into a float4, make sure the last component is zero, and then multiply it by the matrix. (As it says here in the docs). However I'm not a master at matrix math so I might be missing something.
edit: re-read the help doc I linked and it said that when transforming a normal you want to multiply it by the inverted transpose of the matrix. but it seems like a velocity would just be transformed as a regular vector. However It would be interesting to know why you do one thing with a vector and another with a normal.
edit2: Looks like you use the inverted transpose so that the normals will stay perpendicular to the surface. (as explained here).
edit3: I did a test and I'm pretty sure that for a velocity vector you want to use the vector rules and not the normal rules.
Edited by MirrorSword
  • Like 2
