over lapping velocity volumes?
nigelgardiner
I assume you have multiple velocity fields on the sop level:
for all of them to be added into the simulation, you create Source Volume in the dop network for each of them, then plug them into a merge node and finally into the solver
the "add" option means your volume which you are sourcing, will be added into a simulation field. "vel" in your case. if it was set to "copy" , it would instead overwrite the current simulated "vel" field
the initialiaze option simply holds presets how the Source Volume dop can be set up. changing it to "source fluid" should give you what you need.
you may want to look into the "SOP to DOP bindings" tab, that's where it shows you which simulation "fields" will your "volumes" be combined with
Edited by celd
