rolldice Posted September 19, 2016 Share Posted September 19, 2016 (edited) Hi, everybody I'm trying to use CUDA libararies when compiling my custom SOP node. But, I can't because it's really hard to compile it. I succeeded to make a library that includes some CUDA functions. And I tried to attach that library when compiling my custom Houdini SOP node. The compile command is like below : hcustom -l simpleMultiCopy.lib TestSopNode.cpp And I got a error message like below : Making 'TestSopNode.o' and 'C:/Users/user/Documents/houdini14.0/dso\TestSopNode.dll' from 'TestSopNode.cpp' TestSopNode.cpp C:/PROGRA~1/SIDEEF~1/HOUDIN~1.258/toolkit/include\boost/format/alt_sstream_impl.hpp : warning C4819: The file contains a character that cannot be represented in the current code page (949). Save the file in Unicode format to prevent data loss Creating library TestSopNode.lib and object TestSopNode.exp TestSopNode.o : error LNK2019: unresolved external symbol "void __cdecl simpleMultiCopy(void)" (?simpleMultiCopy@@YAXXZ) referenced in function "protected: virtual enum UT_ErrorSeverity __cdecl TestSopNode::cookMySop(class OP_Context&)" (?cookMySop@TestSopNode@@MEAA?AW4UT_ErrorSeverity@@AEAVOP_Context@@@Z) C:/Users/user/Documents/houdini14.0/dso/TestSopNode.dll : fatal error LNK1120: 1 unresolved externals And below is the facts : 1. When I tested to compile normal console application with above CUDA library, no error happened 2. It's not a link error. when I compiled the same thing with wrong library name, I saw a different error : LINK : fatal error LNK1181: cannot open input file 'simpleMulC.lib' 3. simpleMultiCopy.lib has the function 'void simpleMultiCopy(void)' And my compile environment is like below : 1. OS : Windows 7 2. Visual Studio Version : Microsuft Visual Studio Express 2012 3. Houdini version : 14.0.258 How can I compile my SOP node with CUDA library? I'll really appreciate when you give some tips to me. Thanks. Edited September 19, 2016 by rolldice Quote Link to comment Share on other sites More sharing options...
