len function not working (vex)
Blacklisted_Guy
Hi Blacklisted_Guy :)
The len() function is not the problem it's the array attribute you are calling in the function. You already declared it in the line above so now you just have to write the name:
int pointCount = len(curve);
Because if you write int curve[] again you are making a new attribute with the same name as the first one that already exists.
