Object facing vector
Hi
So basically I have a vector and an obj, how can I make the obj face the vector by specifiyng the front axis of the obj? (front, side, up)
Is there a traditional way to do this? Because Im trying to do this myself through Vex and some transforming operations..
Example:
it depends on many factors. what is the source of the vector (another object's transform, another object's attribute, current object's attribute)? on what level you want to make the transform (you want to transform the object itself or it's contents)? do you want to transform one object or many objects? do you have one input vector or many of them? the solution may vary greatly.
On 6/10/2016 at 8:25 AM, dchow1992 said:
hope this helps
matrix_ops.hip
Yes exactly!
I knew that you had to use matrices and vector math like the dot product you used, to rotate the obecjt,but Im not yet pratical of this side of houdini, thank you so much.
I'll credit you whenever I'll use this file you made in a project/video:)
Thanks again :)
