Primuv() Vex Function
Guest xionmark
Guest xionmark
I'm trying to use the primuv() function but am getting an error that I do not understand:
Here's the function prototype:
float primuv (string SOP, float prim_num, string attrib_name, float attrib_index, float u, float v)
Here's a code fragment using the example from the VEX help page:
pop myPOP_Color ()
float grn;
grn = primuv("/obj/geo1/tube1", 0, "Cd", 1, 0.7, 0.3);
When compiled I get the following error:
> vcc myPOP_Color.vfl
"myPOP_Color.vfl" line 7 ERROR (1041) A value type of "void" cannot be assigned
WARNING (2007) Variable "grn" was declared but never used
REMARK (3002) There is 1 unused variable
REMARK (3003) 1 error and 0 warnings encountered
REMARK (3007) No output is generated due to errors in the source code
Is vcc really complaining about trying to assign to a var of type void? Because it shouldn't be trying to assign a value to any parameter of the function call. The error message is confusing me ...
--Mark
P.S. Here's the VEX help page for primuv():
Evaluates the specified attribute at a parametric (u,v) position on
the primitive. u and v are unit values, defined in the [0,1]
interval. When given the "P" or "Pw" attribute, the x, y, or z
image of the (u,v) domain point will be returned. If the primitive
is a face type or a circle, v is ignored.
NOTE: if the primitive is a polygon or a mesh, u and v are defined
in terms of the number of vertices, or rows or columns
respectively. Currently, only the positional attribute of quadric
primitives can be evaluated.
For example: primuv("/obj/geo1/tube1", 0, "Cd", 1, 0.7, 0.3) Will
evaluate the Green component of the diffuse color attribute at a
location on primitive 0 given by the parametric coordinates
(0.7,0.3).
Guest xionmark
I'm a bit confused, primuv isn't a vex function AFAIK. Its a standard houdini expression. The closest thing in vex is prim_attribute. Where is the vex help page that you got this from?
17905[/snapback]
Yep, you're right! I'm wondering why vcc didn't say something like "unknown function"?
I'll try to use the prim_attribute call 'cause I'd like to do this in VEX, I think it'll do the same as the primuv expression.
Thanks!
--Mark
