galagast Posted October 16, 2016 Share Posted October 16, 2016 In the attached file, (sample A) I used a common method of creating a matrix by using Cross Products and an Up vector to orient a set of points towards a direction. Which works great. I'm just wondering, after stumbling upon the Look At VOP (sample B), it seems to pretty much do the same if I: Set the From parameter to the normalized direction that I want. Set the To parameter to {0,0,0} Leave the Up Input blank (probably defaults to {0,1,0} internally?). I'm particularly curious about setting the To parameter to {0,0,0}. I would have thought that the parameter would always need a normalized vector. The help card says: Quote This operator computes a 3×3 rotation matrix to orient the z-axis along the vector (to - from) under the transformation. If an up vector is specified, it will determine the roll. My questions: In the help card, does the (to - from) refer to (to minus from)? Does this essentially mean that the Look At VOP can be used as a Vector to Matrix conversion tool for rotations? Is there a VOP equivalent of the dihedral VEX function? Are there any other methods we could use to do the same effect? Particularly, samples using quaternions would be great. H15.5.607 Indie look_at_v01.hiplc Quote Link to comment Share on other sites More sharing options...
