Find Facing Ratio
Hi everyone,
I'm trying to find all the points on a piece of geo whose normals all point within a certain ratio of another geo's... so basically find all the points of one geo that are "facing" another. The attached file is what I've worked out, but there has GOT to be a better way than that. It's so slow, and I disabled the AttributeVOP that's doing all the work just so it will load for you.
What I'm trying to do is loop over all the points in geo A, and for each point in A, compare its normal to the normal of every point in geo B. If the point's maximum "match" goes beyond a certain threshold, then delete that point. I'm pretty sure this is a horrible way to set this up, but I really haven't come up with anything better. Does anyone have any tips for solving this issue?
Thanks,
Chris
facing_ratio_test.hipnc
