Pause Solver SOP
fortysix
Hey Guys, just one little question: is it possible to pause a solver SOP every other frame? So it doesn't take the prev_frame but every other frame? I've tried to put a switch after the prev_frame with $F%2, but obviously the whole geo will be deleted after the second frame. I think it must be changed in the Dop Import Node itself. Any ideas?
I guess if I only could set the Sub Steps to zero, it would work. But setting $F%2 into the Sub Steps line doesn't seem to work either.
edit: I solved it by setting some forces to zero within the SOP
Edited by fortysix
