HOT Workflow
Yon
Does your foam/bubbles cache also need the displacement maps from the ocean surface?
I know the base does, and spray I assume doesn't if your rendering as points and its flying far away from the surface.
to recap;
base particles
base mesh
foam/bubbles
foam/bubbles mesh
spray
ocean maps
base maps
is this correct? or does foam/bubbles also need maps
thanks
Edited by Yon Anadeyo
